I am trying to add subtitles to an avi to play in my Koss KS5121 DivX player. After browsing these forums for a couple of hours now I have a couple of questions.
First, I read that this DivX player supports .srt and .sub but not .sub/idx (I thought that sub was the bitmap and idx was the timing file?). I then read that .sub files are really .srt files?
Just looking for a little clarification regarding the formats.
Also when using .srt subs I find that they are way out of sync. Which software would be the best for correcting this? I currently have Time Adjuster and Subtitle Workshop downloaded.
I'm pretty new to subtitles so please be gentle. I find these forums are a fantastic resource, though it seems like there is almost too much information
Edit: Is there any way to convert .sub/.idx to .sub? (instead of .srt as that sounds rather painful)
I also have been working with Time Adjuster and think that it is just what I need![]()
Thanks to this site or I would be completely lost!
SUB extension is used for several different subtitle formats. Some of them are textual, like MicroDVD, SonicDVD and some other formats. But, unfortunately, SUB extension is also used for .sub/idx which is graphical subtitle (bitmaps).Originally Posted by Raztax
It is easily done with Subtitle Workshop. Read the manual to learn how to do it.Originally Posted by Raztax
Yes. You have to use Subrip. Again, read the manual - it is simple.Originally Posted by Raztax
If you encounter problems, ask again and describe what went wrong. -
Thanks for the reply. I finally managed to get it working properly though I did run into a rather strange problem. The .srt file I was trying to use seems to have been broken or damaged maybe? It was out of sync by exactly 30 seconds, so I adjusted it to play 30 seconds later and everything seemed fine. The subs were in sync, but gradually, as the avi played, the sub got further and further out of sync again.
I fixed it by using a different .srt file and it is working now, but what would cause this? At first I thought maybe different framerates in the original source avi that the srt was taken from, but arent srt's based on time and not frames? Therefore I would think that the same dialogue would happen at the same time regardless of framerate. Or am I wrong in this assumption?
I am reading the manuals to learn more about the subtitle tools. There really are some fantastic freeware video tools out there! -
You're wrong. And that's probably what happened. You had NTSC subs for a PAL movie or vice-versa. A PAL movie usually has the same number of frames as an NTSC movie, but they're played faster (25fps .vs 23.976fps). As a result, the PAL version of the same movie is usually shorter than the NTSC version, and the subtitle timings are different. -
That would certainly explaiin what was happening then because the subtitles were coming further and further ahead of the speech as the video went on. They must have been PAL subs.
Thanks very much
converting raw teltext data into other subtitle formats
By zorr00000 in forum SubtitleReplies: 8Last Post: 18th Jan 2012, 06:12 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
How to sync subtitle to another subtitle?
By mriddler in forum SubtitleReplies: 6Last Post: 1st Apr 2010, 05:07 -
Subtitle always out of sync
By nonkeljef in forum SubtitleReplies: 3Last Post: 1st Aug 2007, 15:37 -
WMV files go with which subtitle formats?
By binocular222 in forum Newbie / General discussionsReplies: 0Last Post: 18th May 2007, 11:49
