Hi,
I use ASF files, i woud like if you can recommend me a software to brand videos, like the site on text for example, mostly for asf files.
I tried VideoCharge, but the problem with this software, that you need choose how to make the result file with 'format options'. It doesn't support to use the original file specifications. I just want a video to be branded with their original specifications like format, video, audio, etc, (without reencoding it like videocharge), because it will lower the quality.
Is there a simple software that can do this job? thanks in advance
	To add (a permanent) watermark, you have to reencode.
 If it's for streamed video, there's some plugins for WME, that adds the watermark as the video is served.
 /Mats
	I know you will have to re-encode the file, but have you found anything you like yet? I too am in the same position and dont want to use Video Charge.
  i need a convert program with subtitle and watermark supportBy asdasd77 in forum LinuxReplies: 4Last Post: 5th Jan 2012, 03:21
  Watermark removalBy Shrimpy72 in forum ffmpegX general discussionReplies: 3Last Post: 14th Jan 2011, 12:31
  Mencoder watermark helpBy MisaN in forum Video ConversionReplies: 0Last Post: 24th Aug 2010, 13:01
  how to watermark a stream?By rooky in forum Video Streaming DownloadingReplies: 2Last Post: 25th May 2008, 16:22
  WATERMARK help!By legendvij in forum SubtitleReplies: 9Last Post: 13th Feb 2008, 02:52
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
