    Nov 2003
    Australia
    Hi!
    Right now I have a problem playing an encoded file with XviD 1.1.2 Final
    gspot tells me so and when executed with MPC or WMP the video does not show whereas when executed with VLC it does play
    Gspot says the XVID codec is installed so
    Why MPC and WMP do not play the video back as it should
    What's the likely problem here? thanks
    USA
    Your Xvid codec would be the obvious choice as the problem. If VLC plays it, then that would point to a codec problem. In Gspot, try the 'Proposed Codec Solutions and Tests' for the video and see what path it uses.
  3. Note that VLC has an xvid decoder built in so it doesn't rely on an installed xvid codec like WMP and MPC do. I would uninstall and reinstall the xvid codec.
    Nov 2003
    Australia
    Thank you for your replies
    I will try your suggestion remove/reinstall later on
    Nov 2003
    Australia
    reporting back no luck with Xvid unless Divx bundle is installed then andything and everything avi plays ok
  6. If you have Xvid installed go to Start -> All Programs -> Xvid -> Configure Decoder. Under FourCC Support make sure all boxes are checked.
    Nov 2003
    Australia
    I don't kow and remains a mystery to me resetted and checks the options now Xvid works.
    Nov 2003
    Australia
    I have found what is wrong with Xvid installation the xvid.ax server was not registered nor it was possible to register. It was locked by the system so I used unlocker to remove it. Now I want to install Xvid again and Windows would not allow to register it
