Hey all, I've got a bunch of HD ts files that I grabbed off of my DVR. I'm trying to get them to DVD, but I'm not too happy with the results.
I first tried ULEAD DVD Movie Factory 5. The results were pretty bad (grainy), but I'm trying again now with CBR 8000 instead of VBR.
I also used Womble MPEG Video Wizard with better results, but it was still worse than a standard DVD.
I realize there will be loss coming from HD sources, but is there a tool that will give me good DVD quality results for a resonable price? Or is it more a matter of just tweaking settings of the programs I have? I also have TMPGEnc DVD Author 3 which I haven't really played too much with.
I'd like to get at least 3 - 24 minute shows on one DVD. It seems encoding at a CBR of 8000 will be about right for this.
Any recommendations?
Thanks.
	Higher bit rate and CBR should help. There are many other issues for optimization.Originally Posted by zaraspook
 First 1080i to 480i needs an encoder that won't deinterlace to resize. It's the deinterlace that blurs out the resolution. If film source, inverse telecine to 24p allows doing it right with progressive resize. Non-film 1080i needs separate field resize.
 720p is easier to resize but DVD won't directly take 480p/59.94. If film based, the 3:2 frame repeat needs to be removed leaving 720p/23.976 which can then be resized to 480p/23.976. If live video at 720p/59.94, it needs resize to 480p/59.94 then encoding as interlace to 480i/29.97.
 That is what should be done. Many ways to do it wrong.
 PS: All the above applies to "NTSC" TS files. 25fps "PAL" is much easier.
	Thanks EdDV,
 Do any of the tools I listed deinterlace to resize?
 Is there a program that's typically thought of as the best for taking NTSC 1920x1080, 38810 kbps (Variable) video and encoding for DVD?
 Actually, it doesn't even have to be the best. Just something good that has some articles about correct settings would be great.
 Thanks again.
  Difference/Relationship among encoding, re-encoding & decoding?By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 15:46
  ENC encoding versus no ENC encodingBy RL in forum ffmpegX general discussionReplies: 3Last Post: 4th Feb 2011, 18:44
  AVCHD encoding format vs. H.264 encoding format?By coody in forum Authoring (Blu-ray)Replies: 3Last Post: 28th Aug 2010, 21:51
  Encoding MKV to MP4 with .ass subtitles without re-encoding.By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 15:11
  Best settings for encoding with subtitles and then re-encoding for PS3?By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 01:31
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
