Hey,
I just got my HDMI cable, and now whenever i use Auto/ or manually select 1080i upscalling i get a single thick vertical line at the end left of the LCD and even the movie flicker and jerks....
I re-inserted the cable, but still same thing - It happens on all DVD's.
And yes my LCD is 32" Samsung Bordeux (1366 x 768)
Please also tell how to turn-off progressive with HDMI cable transmission.
ANy idea why am not able to switch 1080i ?
PS: The picture get displayed flawless upto 720P only.
The actual TV model number would be helpful. However, since your LCD is basically 720p resolution anyway, I doubt you would get a better picture from a source that is upconverted (dvd player) to 1080i and then down converted (TV) to fit your LCD resolution. Even with a true HD 1080i signal, your TV has to downconvert to match your screen.
Google is your Friend -
The model is : Samsung R7.
What will luk good is secondary, why its not workin is what bothering me at the moment.... -
Are you talking about player settings or TV settings?Originally Posted by craige4u
That player only supports 1080i, not 1080p. Are the settings inconsistent?
Call Sony support. -
Ya, me talkin abt 1080i and called sony support they are a bunch of sick people here in my country who hardly even knw whats upscaling! so no use there and moreover they say its the LCD issue coz its samsung, and samsung people gonna say its player isssue coz its sony.... i am stuck here with my situation....
I guess i got the problem on my NS76(Via HDMI),
When i switch the resolution to 1080i, the progressive light is still glowing, so its not getting turned-off which it should i think and hence jerks and vertical lines problem me getting on my LCD(1366x768)
U all owners of NS76 - plz tell when ur player is outputting 1080i, does the progressive light automatically gets off,i.e, progressive gets off by default? As in mine its not getting off at all... -
I remember reading about the false progressive indicator before. It's not a matter of turning it on or off, the player doesn't support 1080p.
And FWIW, the issue isn't just with your Sony and Samsung products. I have the same issue with my Oppo 971 and my Hitachi TV. 480i/p and 720p work fine, TV will not sync on the 1080i signal.Google is your Friend
On a 1080p TV (46inch) upscale to 720p or 1080i?
By Chrushev in forum Newbie / General discussionsReplies: 1Last Post: 22nd Oct 2009, 20:22 -
52" LCD TV will not display 1080i?
By David97 in forum Newbie / General discussionsReplies: 3Last Post: 6th Mar 2008, 09:05 -
Watching HDV footage - 1080i CRT vs. 720p LCD
By JohnnyMalaria in forum DVB / IPTVReplies: 12Last Post: 21st Feb 2008, 02:29 -
DVD Players that "upscale" to 1080i
By geek2330 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Jan 2008, 17:01 -
Mono only when capable of Stereo sound on new LCD Sharp Aquos
By bear2616 in forum DVB / IPTVReplies: 3Last Post: 12th Sep 2007, 16:07
