I tryed to open the System Information tool but it wont open!
i tryed to do it by clickin "start" > "Programs" > "Accessories" > "System tools" > "System information" - but nothing happened!
i''ve also tryed to do it through "Start" > "Run" > msinfo32.exe - but nothing!
any ideas?
any help appreciated!
Thanks!
Maybe msinfo32.exe or one of its dependants has become damaged by a virus or a power loss/bad shutdown.
First do a complete virus scan, then do a complete hard disk check/repair. -
Also try using the run command. open run
type cmd
then type in the command prompt window sfc /scannow
that will check for corrupted or missing files.
Try a test and see if Ctrl-Alt-Del brings up the Task Manager. -
mh2360, didnt came up...
TBoneit, thanks for the reply man!
is this scan gonna replace hardware drivers too?Originally Posted by TBoneit
cause some of my hardware drivers dont have microsoft signature... (installed them from a CD)
thanks for your help! -
No, it only checks the windows components. Not drivers. It checks to see if they are missing, corrupted etc.
TBoneit,
it didnt help man!
i guess i'll just repair the OS and it'll fix it...
thanks anyway!
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
Broken AVI Files after data recovery "FFmpegSource: Couldn't find stream information"
By fixavifile in forum Newbie / General discussionsReplies: 8Last Post: 28th Jan 2010, 04:24 -
System restore problems- "next" button
By Super Warrior in forum ComputerReplies: 1Last Post: 30th Jun 2009, 19:22 -
HTPC case fits "Scythe Ninja revB" - full system advice please...
By Steve Walsh in forum Media Center PC / MediaCentersReplies: 16Last Post: 20th Oct 2007, 08:58
