hi
could you tell me how to configure a bush dvd recorder vhs combo a Humax hard drive recorder to a Panasonic tv .They all have two scarts a piece
thqnks Nobby
Depends on how you are wanting to use them. For playback just attach the video outputs of each player to the TV inputs.
Google is your Friend -
i would like to use the vhs tape to record as well as the hard drive recorderof the tv
nobby -
Presumably you want to record from the Humax inbuilt Freeview tuner, but what about the VHS? Do you only want to be able to record off air from it's own inbuilt analogue tuner or do you want to be able to record what the TV is displaying? Is your Panasonic and IDTV or analogue only?
record what the tv is displaying. i am set up now to obviously record all freeview channels on my Humax. i have just bought a dvdr/vhs combo to transfer videos onto dvd and i reckon it may as well be able to record on both for use on other stuff in another room
If you connect the Humax to Scart 1 on the TV, that should get that working normally. Connect the combo unit to Scart 2. On all modern Panasonic TVs, Scart 2 can by configured to output whatever is being displayed on the screen, be it the signal from the TVs own tuner or whatever it is showing that is coming in from Scart 1. As long as you can set this, you should be able to record to VHS by selecting the source as the Scart input on the combo.
thanks for the suggestion i will try that tomorrow and let you know
nobby
re-configuring virtualdub default compressor codec to another ?
By vhelp in forum Newbie / General discussionsReplies: 9Last Post: 5th Aug 2012, 13:22 -
Need help configuring capture configuration
By tomarwater in forum Capturing and VCRReplies: 4Last Post: 9th Feb 2010, 07:11 -
configuring the sound
By alintatoc in forum Newbie / General discussionsReplies: 6Last Post: 14th Mar 2009, 09:34 -
Configuring microphone w/ Realtek HD Audio
By Sean O'Scare in forum AudioReplies: 0Last Post: 24th Feb 2008, 08:05 -
Easier way of using a gamepad rather than manually configuring every button
By ryangarfield in forum ComputerReplies: 3Last Post: 24th Jun 2007, 10:29
