Hi -
I am having a problem ripping a tv series disc to xvid.
What it looks like is that the IFO files are referencing differnt VOB's so VTS_02_0 will be the first part of the show and the second could possibly be under VTS_03_2.
Do I just have to do trial and error and match up each vob I rip or is there an easier way of backing up these episodes? I do not want to back up the DVD to DVD but back up each individual episode to have more on one DVD for ease of access?
I tried searching but my search fu is weak and I did not find anything that I thought that helped.
I have installed:
dvd decryptor
AutoGK
I have followed this guide with success in the past:
https://forum.videohelp.com/viewtopic.php?t=301015
but have not come across anything like this before.
Thanks for all the help!!!!
give fairuse a try, if i recall you can select the stream you want,and the quality is pretty good too.
There's an easier way - a much easier way. Decrypt by PGC. Use DVD Decrypter in IFO Mode (which isn't the default) and it'll give you the longest PGC (episode) by default. But if you look around you'll find the rest. Decrypt each to its own folder.
With them already on the hard drive, open the IFOs that contain the various episodes in PGCDemux and demux them, or "Create A PGC VOB" instead. Then feed the result to AutoGK. -
Put DVD Decrypter in IFO mode. This will allow you to rip individual episodes. If you also desable file splitting it will produce one VOB per episode.
Thanks for the feedback! Will give a go this weekend. Will post if I have more problems
Newbie question about blu ray ripping and converting
By pete7769 in forum Blu-ray RippingReplies: 8Last Post: 12th Jan 2012, 16:02 -
Ripping tv series disc
By pearce88 in forum DVD RippingReplies: 6Last Post: 1st Oct 2010, 10:24 -
Ripping my collection of TV series dvds help
By meridiusuk in forum DVD RippingReplies: 1Last Post: 13th Jun 2010, 11:47 -
Ripping a TV Series with Multiple .VOB files
By currysteph in forum DVD RippingReplies: 6Last Post: 6th Apr 2010, 02:27 -
Help Ripping TV Series
By fordprefect138 in forum DVD RippingReplies: 9Last Post: 21st Dec 2009, 08:31
