Has anyone had any experience with this machine or even LG recorders in general?
I am interested in a DVD recorder with a hard drive that can burn +DL media and ofers the ability to record in standard and FR modes. Pioneer DVR-640 is my top choice, but they are almost impossible to find and they are being high-jacked on ebay.
Thanks.
If you search a bit through previous topics in DVD recorder section, you can find a few topics about LG recorders.
Here I described my LG RH188S:
https://forum.videohelp.com/viewtopic.php?t=319987&highlight=
I've used that machine daily for last 5 months and I haven't noticed any faults. -
I did not like the 519. It was more like a computer and less like an easy DVD recorder. It also did something weird on encoding, everything had "digital" look to it. I think the interlace was messed up somehow. And then it was pitiful quality past 2 hours.
The whole machine was weird. It runs Microsoft firmware.Want my help? Ask here! (not via PM!)
I have not seen a LG recorder that can do FR mode, but have seen in another forum where a reviewer said it did. LG's do have a timer recording mode ( AT for auto ) in which the recorder determines the remaining time left on a disk and makes a decision about which mode to use based on the start and end time entered in the timer, but it is still choosing from XP, SP, LP, etc.
They may be confusing this with FR mode in which, for example, a tape is 1 hour, 10 minutes long and the recorder chooses a resolution and bitrate to fill the disk as can be found in other brands.
DVD Recorder/VCR With No Tuner - Link to Broken Tunered DVD Recorder
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2008, 03:05 -
Will a DVD-Recorder to DVD-Recorder copy lose quality?
By blackmetal in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jan 2008, 05:54 -
LG LRM-519 and transferring files to computer
By bmoret in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2007, 23:42 -
Upgrading LG LRM-519
By dbswissy in forum DVD & Blu-ray RecordersReplies: 2Last Post: 20th Jul 2007, 14:26 -
Toshiba RD-KX50 DVD Recorder / HDD Recorder
By Kinddomaker in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jul 2007, 22:19
