can any one help? I have what I thought was a screen problem as there are small green/pink dots all over my screen. I have tried another screen but the same problem occurs. When I move the mouse the dots become worse. before I take the back of the pc and check inside it has anyone else had the problem or can anyone shed any light on it? Could it be a virus? here is a picture of the screen
Cheers
I had a similar problem some years ago when the fan on the graphic card had died...I fixed the fan but it didn't help so I had to get a new card.
Sounds like a video card crapping out. If you have onboard graphics you have a problem. If its a card you can replace it. If its onboard graphics you cant but you can buy a card if you have an available agp or even a pci slot. Though pci cards are harder to come by. If you dont have a slot you'll need a new motherboard.
looks like I'll have to get me screw drivers out over the weekend then
Cheers -
down to the graphics card so replaced it and all is fine, for now
I think an easy way to fix dots flickering (sample included)
By jairovital in forum RestorationReplies: 28Last Post: 11th Jan 2012, 16:39 -
Subtitles in MPC displaying as splashes of dots
By meldavid in forum Software PlayingReplies: 3Last Post: 28th Aug 2009, 00:47 -
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 18:23 -
LCD Screen: video plays on desktop but appearing black on big screen...
By Heyjoojoo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2009, 18:36 -
Screen goes black for half a second in Screen Virtuoso avi video stream.
By 2prfm in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2007, 12:16
