I have an mkv file that I want to demux and make into a dual audio DVD with subtitles. However I load the video into vdub mod and go to streams. I select full processing and compression, no formats are available (happens when there isnt an available decompressor).
Audio description as appears in Vdub.
There are 2 streams with the similar info (tags are different naturaly).Code:Source : Matroska file Desc : Audio Stream 1 [tag 0x0000, Unknown Wave Format], ID [A_AAC/MPEG2/LC/SBR], 6ch, 22050Hz, 166.6kbps Length : 00:25:03:129
When I play it in core media it plays fine, audio shows up as dolby digital 5.1.
Is there a program I can use to demux the files from the video into an Ac3 or something?
Results 1 to 10 of 10
Try demux with mkvextractgui instead. And then convert it to ac3 with daudiok,belight, etc if it's not already ac3.
Besweet/belight didnt work either. Log reports the track length as 00:00:00:00
Can you play the .AAC file normally ? Whoops, I just re-read your first post.
Yup, I noticed how few apps out there can deal with 5.1 (6ch) AAC.
FAAD will work properly to convert it to WAV, then you can Aften it.
Rename your aac file to AUDIO.AAC and try the following:
aac2wav2ac3.rar
I recall reading somewhere that aften is smart enough to do the proper channel remapping on this type of material. -
This is going to be a huge affair isnt it :P
Well i cant do anything with it like it is anyway, I cant even convert it to AVI to put on my mp3 player so i guess Ill have to try whatever I can 8)
Ill try your suggestion and post back.
EDIT: How do I use the Faad.exe command line? (there a gui available? :P )
Urg I hate MKV, why cant pepple just stick to common codecs! its annoying! lol -
Yeah I know, I have my PC connected to my TV and my stereo (350watts 2ch stereo from the 80s) and that is typicaly how I watch my videos, but I would like it on a DVD so I can play it in my portable unit. Carrying my laptop everywhere isnt always the easiest thing.Originally Posted by Baldrick
Okay, Wavepad worked for saving to wave, Though I didnt see whether it saved all 6 audio channels. -
Download the RAR file I posted above
The .Bat file will convert audio.aac to WAV, then it automatically encodes the WAV to 5.1 AC3
additional audio decoder needed to play this soundtrack-Dolby AC3 Audio
By tbone1209 in forum AudioReplies: 6Last Post: 19th Jun 2011, 20:58 -
5.1 audio decoder
By robinmishra in forum AudioReplies: 4Last Post: 24th May 2011, 18:22 -
FFDshow audio decoder level is way too low...
By MidnightMike in forum AudioReplies: 2Last Post: 4th Dec 2010, 00:34 -
Alternative to eac3to or using different audio decoder
By badreligionhead in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2009, 13:23 -
Combining PowerDVD 7's Audio Decoder and Microsot's MPEG-2 Video Decoder
By Dark Alpha in forum Software PlayingReplies: 4Last Post: 11th Sep 2008, 18:44
