Hi all,
I am trying to capture some VHS tapes, but need to do so in segments of time or size. The current software I have is Pinnacle Studio Plus v10, but so far it doesn't seem to give me the option to capture in segments...unless I do it manually.
Here is what I would like to accomplish:
I am hoping to take a 2 hour VHS video and let it run its course while capturing the entire contents in mpg format. Here's the catch...I need to split the contents in about 100 or 200 MB segments along the way.
I can do this manually now, but I have several tapes to go through and would like to invest in software that will automate it. Pinnacle might allow me to do this, but if it does I may be missing something.
Can anyone recommend software out there that will automatically split the captured mpg files along the way...either by time stamp or by file size. Doesn't matter to me. Another option would be software that will split a captured video file into segments without any extra codecs to be installed. Thanks for all your help!![]()
Results 1 to 1 of 1
Using my laptop to capture DVD segments in WMV format
By kreskin in forum Capturing and VCRReplies: 10Last Post: 24th Dec 2011, 10:47 -
Combining segments from different titlesets
By dt3kt in forum Newbie / General discussionsReplies: 5Last Post: 14th Jan 2011, 13:28 -
What to look for in Video Capture/Software 4 newbie?
By rivrbyte in forum Newbie / General discussionsReplies: 16Last Post: 1st Mar 2010, 13:42 -
WinDV - captures in segments ?
By Tafflad in forum Capturing and VCRReplies: 10Last Post: 28th Feb 2010, 03:34 -
AVI - split by no. of segments
By macpraveen in forum EditingReplies: 4Last Post: 12th Jun 2009, 23:30
