Looking to do VHS captures direct to DVD Standalone, and some are generated tapes, showing very obvious Chroma shifting/drooping. I know how to easily correct this problem in Vdub and AVIsynth, but capture thru PC isn't an option here (Too many tapes), so is there a TBC/Enhancer that can correct the color shifting VERTICALLY?
The VT used is a horse (JVC BR-S525DXU) and has an internal TBC that can correct chroma shifting horizontally only. Some enhancers can correct the horizontal shifting but I'm looking for one that does it BOTH vertically and horizontally. After 2-3 generations, VHS clearly show a shift in both directions.
The ACE Enhancer/Converter is the only one that I found could do this (it had a "chroma drooping" button to correct it by 3 lines) but unfortunately is impossible to find nowadays. Any help appreciated!
Also, looking for a hardware equipment that can actually delay video signal by several frames.
Arnaud
I have the ACE enchancer and it is indeed a very good product. It is sad that GTH Electronics (www.gthelectronics.com) forced by the new European Laws to stop manufacture it.
You can still find it on E-bay.La Linea by Osvaldo Cavandoli
Chroma shift after field-matching
By drawar in forum EditingReplies: 4Last Post: 25th Apr 2012, 05:07 -
Chroma shift help needed
By Cherbette in forum RestorationReplies: 26Last Post: 18th Jan 2012, 21:46 -
ADVC-55 and color shift?
By pgoelz in forum Capturing and VCRReplies: 28Last Post: 16th Mar 2010, 18:10 -
Shift the subtitle
By cheerful in forum Newbie / General discussionsReplies: 4Last Post: 9th Nov 2007, 17:13 -
Got a DVD plays correct, copies correct but refuses to write on a blank DVD
By cemman in forum Authoring (DVD)Replies: 16Last Post: 21st Jul 2007, 16:09
