I need to edit a DVD. I do not have the MPEGS. I use Vegas 7. How can I turn the DVD back to MPEG2s? TKS
Sorted: Found answer in a sticky https://forum.videohelp.com/viewtopic.php?t=323286
Yup. Another way (my favorite) is to configure DVDshrink to ignore the 1GB limitation on VOB sizes and save the DVD into a hard disk folder as a huge VOB file. Then, just change the ".VOB" extension to ".MPG" and, Eureka, an editable MPEG2 file. The non-MPEG information in the VOB file is just ignored by editors and demux utilities.Originally Posted by redwudz
DVD Decryptor had that function as well:
Use PGC mode, set to not split files. Save program. Result was one big Mpeg..... -
Just a word of caution when renaming VOBs to .mpgs. VOBS are split at the 1GB mark, irregardless of chapters, etc. If you just convert one VOB to a .mpg, you may likely find the video extends to several other VOBs. Extracting the whole DVD main video to a single VOB or .mpg is best.
How to convert squashed DVD aspect ratio back to normal??
By EricBalir in forum Video ConversionReplies: 5Last Post: 9th Sep 2011, 22:36 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
Can I convert an avi back into a DVD and restore original quality
By Vidonizer in forum Video ConversionReplies: 1Last Post: 11th Nov 2009, 14:32 -
How to convert DVD back to individual files
By mysts in forum Newbie / General discussionsReplies: 1Last Post: 19th Jul 2008, 07:19 -
convert dvd back to imovie on Mac
By etwicky in forum MacReplies: 4Last Post: 9th Jul 2008, 22:09
