Hi,
I'm going crazy trying to get this ffmpegx to work. I was told it's the only free and best way to convert .mov to .flv. Everytime I drop a video into the Source Format it says unrecognized. I think this is because the mpeg2enc binary has not been installed. I'd love to install it but when I go to the site that offers it for download I just get a jumble of code. The other two binaries are installed fine but this one is not giving me a break. Can someone send the binary to me by chance? Or if this is not the issue it says "Unrecognized" can someone help me solve this?
You would get more answers in our ffmpegx forums. And it would also help us if you filled out your computer details. I'm guessing you have a Mac or you wouldn't be using ffmpegx.
Moving you to the ffmpegx forum.
First, ffmpegx is technically shareware, not freeware.
Second, the answer to your question is a couple of posts below yours, courtesy of Case. See it here: https://forum.videohelp.com/viewtopic.php?t=328758
That "jumble of code" is in fact the code you want, so it's actually working fine.
a/ When converting .mov to .flv, you won't need the mpeg2enc binary, as that binary is only used for conversions to MPEG-1/-2, e.g. VCD/SVCD/DVD.
b/ Because your source file is .mov, you may want to tick the "Decode with QT" checkbox in the Options tab. Then ffmpegX uses QuickTime to read the source file, which may help for codecs that ffmpeg isn't able to decode on its own.
c/ If it still won't convert, then it would be helpful to know some details about your source file: video codec, frame size, framerate, audio codec, sample rate, duration. 'Show Movie Info' and 'Show Movie Properties' in QuickTime Player should help you find these.
FFMpegX Audio problems
By Cowchan in forum Newbie / General discussionsReplies: 0Last Post: 11th Dec 2011, 10:00 -
Muxing problems with ffmpegx
By Themroc in forum Newbie / General discussionsReplies: 0Last Post: 5th May 2009, 19:49 -
ffmpegx problems with RM to AVI
By mgarman14 in forum ffmpegX general discussionReplies: 13Last Post: 2nd Sep 2008, 12:45 -
ffmpegX Installation problems....
By maiof06 in forum ffmpegX general discussionReplies: 1Last Post: 31st Aug 2008, 01:32 -
Problems with ffmpegX
By KeepItSimple in forum MacReplies: 2Last Post: 5th Apr 2008, 20:46
