Hi all![]()
I currently use TmpgEnc DVD Author 1.6 but don't like the menu options, so I've downloaded the trial of V3 which now has encoding.
A lot of the stuff I want to author is 544x576 DVB recordings. With V1.6 I could fool TmpgEnc into authoring by patching with DVDPatcher, but V3 insists on encoding, even though 544x576 DVDs work fine on every DVD player I've ever tried.![]()
So is there a way of turning off the encoding in V3? Otherwise I'll have to stick with V1.6.
Another irritant is that to use a still image from the video in a menu it looks like you have to set the point to both the start and end points - you can't just drag the seek bar to the frame you want.![]()
Any solutions?
Thanks![]()
I haven't found a way to stop the RE-encoding of 544x576 material - Since I upgraded to a dual-core system I usually stretch and re-encode with an avisynth script into CCE. Before the upgrade I usually either just used the free DVD Styler to author a DVD with a simple top menu or recorded onto my DVD recorder and then ripped the dvd onto the PC. (It's also worth checking if the channel you're recording from has a +1 channel which broadcasts at 720x576. (E4+1 for example)
As far as the still image in a menu, do you mean as a background or as thumbnail(s)? Either way, you can turn off the motion menu settings for that item and then just set the start point. -
Thanks TimA-C
I think I'll save my £ and stick to 1.6 then - a shame, because I really liked the new menu wizard but my time's more important
For the still image I meant for the thumbnails. I thought I had turned off motion settings but maybe I was missing something.
Oh, well - at least I have an answer now - thanks
dvddecrypter stop recognize dvd in drive, got img burn,it stop recognize
By ninjinturdle in forum Authoring (DVD)Replies: 3Last Post: 21st Jun 2011, 12:30 -
TMPGENC encoding problem
By whschlebaum in forum Video ConversionReplies: 0Last Post: 26th Apr 2011, 22:22 -
TMPGEnc Author Keeps Re-encoding
By lostinspace00 in forum Authoring (DVD)Replies: 13Last Post: 8th Apr 2011, 08:16 -
Encoding using TMPGenc 4.0 Xpress
By abdul_sma in forum Video ConversionReplies: 1Last Post: 19th Jun 2010, 07:15 -
TMPGEnc Plus Encoding
By crys94 in forum Video ConversionReplies: 9Last Post: 29th May 2008, 22:23
