Hello all, havn't been here for a while, since my PC died.
Is there any software out there yet, that can handle an .avi with a 24 bit/96khz sound track and convert it to DVD? Every converter I've tried crashes on me.
Thankyou
Kind Regards
Mike
	See. http://www.dvddemystified.com/dvdfaq.html#3.6Originally Posted by mikee55
 For DVD-Video see 3.6.2
 For DVD-Audio and SACD see 3.6.1
 The problem for DVD-Video is maximum bitrate per audio channel.
	There are a number of apps out there that'll work with 24/96 audio, able to convert to something that is DVD-video compliant (AC3, 16/48PCM, etc). Vegas/Soundforge is one, there are others (though not many that are free/shareware). You won't really be able to do true comparisons without (24/96) supporting hardware...
 Big question is: What do you have, and what do you want to end up with?
  192 vs 96 vs 48 vs 44.1 KHz?By therock003 in forum AudioReplies: 22Last Post: 19th Nov 2012, 10:55
  Which player S/W and H/W can play 12.3 Mbps 48 KHz 8 channels PCM wave?By Bonie81 in forum AudioReplies: 3Last Post: 8th Jul 2011, 20:30
  Is AAC 48.0 KHz good audio for a bluray rip?By AndyD in forum Blu-ray RippingReplies: 3Last Post: 5th Jun 2010, 19:18
  Is a 44.1 KHz audio capture OK for a compliant DVD?By c627627 in forum Capturing and VCRReplies: 8Last Post: 23rd Mar 2010, 05:29
  capture of S-Video and PCM 44.1 kHz at the same time ?By nidi in forum Capturing and VCRReplies: 16Last Post: 23rd Apr 2008, 15:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
