In Adobe Premiere, how do you make titles so that they appear like someone is typing them on a keyboard.
The way it is done is you put a Crop Effect on the title or word and then animate it using hold keyframes, letter by letter.
Or, use After Effects and you simply apply the correct text animation preset."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Adobe Premiere Elements 7- How do I make it fullscreen?
By robvs in forum EditingReplies: 3Last Post: 20th Jan 2014, 06:13 -
Adobe Premiere Pro How do I make the video Bigger?
By Devilsadvocate in forum EditingReplies: 5Last Post: 25th Mar 2012, 16:44 -
Super Easy Question about COMPRESSION USING ADOBE PREMIERE PRO CS5
By BronProductions in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2012, 19:48 -
MP4Cam2AVI to Adobe Premiere Question
By jwfc in forum EditingReplies: 3Last Post: 16th Nov 2008, 15:52 -
Adobe Premiere Pro 2.0 project file/autosave question
By wwervd316 in forum Newbie / General discussionsReplies: 0Last Post: 20th May 2008, 20:14
