    Apr 2006
    Is there anyway to fix it to make the pixels less noticeable on the TV screen?
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    turn the sharpness way down to nothing or do you mean macroblocks ?
    Apr 2006
    well the original video before i convert has pixels on it already
    im not sure if it's called macroblocks, but those are the small square that appear on the monitor/TV screen.
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    those are macroblocks, not pixels , not the same thing
    you can try using msu deblocker
