I have looked into this wrapper that I need to get VirtualDub to see my ATI AIW using the VFW drivers. My question is : If I install this does that screw up my MMC 7.5 install? Or anything else for that matter?
System Specs:
Windows XP pro
AMD 1.2
ATI AIW Radeon
512 mb PC133 RAM
60gig ATA/100 HD
10gig ATA/66 HD
12x CD_RW
Thanks,
TheNob
Have the same card, ATI AIW Radeon 32 MB DRR, on a AMD 1.7 GHz with 120GB WesternDigital HD, have not had any problems running anything, VirtualDub/ VidCap/MMC 7.5. It all works with this wrapper at least on my system
Bud -
The wrapper is nothing more than a Window Video Driver. You have to have a good one to get VirturalDub to see your ATI as a capture device.
Once you have it and install it,... Vdub will work. It will have no effect on you ATI card or MMC 7.5"Technology",...It's what keeps us all moving forward. -
Try this...it was located in the Capture Section of this site...
http://shopgeo.virtualave.net/wrapper.zip -
Have an all in wonder radeon would like to use vdub have wrapper but don't know how to use it. Was told directx 8.1 would do this in conjuction with mmc 7.1, tried that. Any help out there?
After you unzip the Wrapper files, right click on the one INF and do the install, it will take care of itself........I would reboot after just ot be sure......
Bud
ATI TV Wonder 650 PCI - Black Screen in virtualdub
By HidenSeek in forum Capturing and VCRReplies: 50Last Post: 21st Mar 2012, 10:18 -
Ati 600 usb stick and virtualdub capture
By buckethead in forum Capturing and VCRReplies: 4Last Post: 8th Mar 2011, 17:13 -
Diamond ATI Tv Wonder 750 USB and virtualdub
By buckethead in forum Capturing and VCRReplies: 9Last Post: 31st Jul 2010, 04:34 -
vfw wrapper help
By video_2010 in forum Capturing and VCRReplies: 0Last Post: 21st Jul 2009, 15:48 -
Where to get WDM to VFW wrapper
By SuperFlyBaconG in forum Capturing and VCRReplies: 1Last Post: 29th Jul 2007, 10:30
