Here's my problem:
I have an MPEG and I wanted to burn it into a VCD, so just to test if I had or not to convert the file with TMPGEnc, I tried to add it to a VCD that I was doing in VCD Easy. VCD Easy analysed the file and said it was an invalid file... quote: " '*.mpeg' analyse failed: input mpeg stream has been deemed invalid -- Aborting".
So I though that I should probably convert it with TMPGEnc, so that's what I tried, and every time, TMPGEnc freezed in the exact same part of the video (when it's converting it) (the source video appears to be PAL, and I've tried using NTSC, NTCSFilm and PAL templates.)
I also tried to use a program called Windows Movie Maker that came with my PC to try and transform it to asf or vmw and then transform it into mpg, but again, the file is aparently invalid.
I also tried capturing the video with camtasia, a program that can make avi's from whatever you have on your screen, this didn't work either, the area in which the video was playing was just black space when I watched the avi I had just made.
So I dunno what to doThe weird thing is that I can watch this mpeg video with no problems on the Windows Media Player... anyone has an idea of what I can do to convert this file so that I can burn it into a VCD?
Try opening the file using VirtualDub.
If that succeeds, move the slider bar and check if you can see all frames.
Try frameserving to TMPGEnc and encode to compliant VCD file.
If that fails too, check out http://nickyguides.digital-digest.com/index.htm
Look for Converting Stubborn MPEGs.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
cut one MPEG file to many small mpeg file automatic
By Cazz in forum EditingReplies: 2Last Post: 8th Aug 2010, 12:11 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 18:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36
