Hi there,
This place has been helpful in the past, so I hope you can help me with my problem.
I am in this one point in my project in which I need to make a slideshow.
My pictures vary in size and quality, but what I want to do is to have the viewing camera scroll across the picture AND zoom in/out at the same time.
I cna get the movement...which is quite easy with the key frames (set location here...go to end of pic and set location there...tada!) However there does not seem to be a function to zoom in/out as its moving.
If you have the Led Zeppelin DVD (2003) on Disc 1 during the jam in Communication Breakdown, it achieves exactly what I want.
Any help would be greatly appreciated...
ZAID KHAN
check out the scaling and position effect under motion in the video effectOriginally Posted by flipzoso
http://www.wrigleyvideo.com/videotutorial/tutdes_ppro_photowall.htm
It's for PP1.5 but shouldn't be that difficult to adapt. -
ahh yes, thanks. It turns out my auto adjusting scaling wasnt selected..so it would only do vertically or horizontally. Threw me off, but I got it now.
Thanks for your help.ZAID KHAN
Questions about using Adobe Premier Pro
By Graemey in forum Newbie / General discussionsReplies: 2Last Post: 21st Mar 2010, 06:02 -
not enough disk space - Adobe premier Pro 2.0
By Reggie6966 in forum Newbie / General discussionsReplies: 11Last Post: 8th Nov 2009, 03:07 -
Adobe Premier Pro to dvd
By tat2loo in forum Newbie / General discussionsReplies: 7Last Post: 29th Apr 2008, 12:57 -
Adobe Premier Pro - Mpg - Skipping.
By primalmedia in forum EditingReplies: 1Last Post: 7th Nov 2007, 10:35 -
5.1 AC3 and DTS in Adobe Premier Pro
By zerohash in forum Authoring (DVD)Replies: 6Last Post: 25th Sep 2007, 07:39
