Closed Thread
    May 2007
    Hello,
    I download a lot of torrents, usually in DVix or .AVI type format, then I use a program called MediaNow that converts them into DVD format. I really haven't had any problems but recently I downloaded the movie the Matrix in and it was in .AVI format. The sound plays fine on my PC, but when I pop the DVD that I burned it on into my DVD player it plays the movie but I hear no sound. I double checked that I had burned it with under SP (Standard Play) and that it was set to NTSC format as well as the correct audio format that I use with every DVD that I create. Any assistance with this would be greatly appreciated, I'm totally stumped as to what the problem might be.
    Thanks - Vic
    You are in breach of the forum rules and are being issued with a formal warning.
    VideoHelp is NOT the right place (if there is any at all) to get help with your illegal downloads.
    Read the rules again (the short version is on every "new post" form).
    / Moderator mats.hogberg
  2. Member Soopafresh's Avatar
    Jan 2004
    Easy one. Just buy the Matrix on DVD.
