i would like to know what the best, easyest software for taking video from a vedio camara, and editing it into a dvd. i have use pinnacle studio with good secsses intill it gose to burning the dvd and it turns to crap( freezes and glitches)
Let me know
kris
	Pinnacle Studio is famous for crashing. It has been going on through 10+ versions. If you want entertainment, visit their support forums. If you want an improbable video game experience, try their beta test program.
 That isn't to say other programs won't crash. I'm trying to think of another that does like that .... but it does happen so I've heard.
 I can't recall an encode crash that I've experienced other than a disk full situation.
 I've heard Roxio can be rough. I don't know. I last used them for version 5 (before DVD).
	Enough of memory lane, what kind of camcorder and computer do you have? Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	I don't use the actual editing software for burning. The way I do it is to create the DVD files with Adobe Premiere Elements, but instead of burning it to a disc, you can choose to burn it to a folder on your computer instead. I had plenty of discs turned into coasters before I realized there was a better way. So now I burn it to a folder, then use seperate burning software (sonic record now dx works fine) and haven't had a coaster since. Hopefully other software gives similar options.
  Video Editing Software: mkv, h264 & DTS Editing?By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 02:29
  What is the best editing software for editing headBy sonic12345 in forum EditingReplies: 1Last Post: 4th Jul 2010, 22:05
  Editing as a career / editing freelance jobsBy ayim in forum Newbie / General discussionsReplies: 8Last Post: 15th May 2010, 22:31
  Basic editing: which Mac program for my DVD editing situation?By Nuevonik in forum MacReplies: 4Last Post: 8th Jan 2009, 08:06
  EditingBy dantheman6 in forum EditingReplies: 5Last Post: 3rd Jun 2008, 00:32
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
