    May 2007
    i have tried many ripping software and i cannot get any movie i have to 700mb...they all make 2 avi files...how can i make just 1 file? i've got most of the programs so whatever is the best to use, please tell me...thanks for any help.
    Dec 2006
    Here,where do you think?
    What did you use? AutoGK? Super?, FairUse wizard?????
    thanks for any info.....
    " Who needs Google, my wife knows everything"
    May 2007
    fairuse, dvddecrypter, imtoo dvd ripper platinum 4, magic dvd ripper, and some others...the option for 700mb is on some of those, but when i do that, it still puts it into 2 files
    Dec 2006
    You are trying to convert DVD to AVI format right ?
    FairUse is pretty good ,check options set 700MB size...
    DVDdecrypter does not convert to 700MB avi... not sure about magic as i don't use....
    Try DVDFAB Platinum, comes with 30 day free trial...
    But I'm surprised Fairuse is not working for you...
    AutoGK works great as well......
    May 2007
    fairuse will always say access denied...i have the free trial one, do i need to full version?
    Dec 2006
    Install the celtic_druid free version.... and try it.....
    https://www.videohelp.com/tools/FairUse_Wizard
    BTW, first backup your owned flick to HDD then use fairUse....if that is what you are trying to accomplish......
    May 2007
    i didnt know i had to rip it first then make it to 700mb...i will try that..thank you so much for your help
