It would be great if in addition to converting my VHS to DVDS with it, I could also work on my analog music collection as well.
Thanks for the opinions!
http://www.dak.com/reviews/Tutorial_LP.cfm
This is a cheap product - and a blatant sales pitch.
But it provides an understanding of how to convert your music. With a little effort you can find freeware to perform the functions that Windows media player does not provde. -
Thanks Jerry..er , I mean Old and in the way(midnight moonlight my favorite)
I suppose I was trying to avoid the work of changing video/audio set-up and figuring out how to plug a cable into a soundcard. I thought that if you could just connect a cassette player to the "audio in" of a video capture device, I could use one gizmo for the same thing. No idea if these things will convert to MPEG-2s for burning CDs.
Thanks for the tutorial -
Well if you try it and you can play the audio, audiology will capture it and can export to wav or mp3.
I look like Jerry and I were separated at birth, especially since I resisted my wife's suggestion for a haircut. My musical abilities are limited to listening but I too am fond of midnight moonlight. -
Thanks for the tip. I am quickly moving toward the "bear" look too and will probably have to start shopping for black T shirts ala Jerry very shortly.
ads dvd xpress dx2
By joselito in forum Capturing and VCRReplies: 0Last Post: 29th Aug 2009, 11:21 -
DVD Xpress DX2 on Vista
By dolfan43081 in forum Capturing and VCRReplies: 31Last Post: 20th Jul 2008, 20:56 -
Newbie problem with ADS Xpress DX2
By jimmy_fowler in forum Capturing and VCRReplies: 2Last Post: 1st Jan 2008, 08:09 -
MPEG-2 bitrate > 4000 with DVD Xpress DX2?
By miamicanes in forum Capturing and VCRReplies: 2Last Post: 11th Sep 2007, 09:12 -
Major Problem with DVD Xpress DX2
By AcidFMHQ in forum Capturing and VCRReplies: 0Last Post: 22nd Aug 2007, 06:02
