    Mar 2007
    Hello, i hope someone can help with this odd problem.
    I have 17 different Mpeg files i want to burn to DVD. I converted all the files with the SUPER program to Mpeg1, Audio MP3. I opened up Ulead Movie Factory 3.5, imported all the files into the program. The accumulated file size is 4.10 GB. But the time size is over 4 hours. So just before i started to burn the DVD i noticed the woking folder needed to be only 3.8 GB (i thought that was odd) Usually the working folder is much bigger. So after many hours of converting and burning etc.... an error occured saying something about not enough disc space. Well i had over 15 GB to play with so this is odd. I hope someone can help with this little issue. Here is an example of one of the files. that may help. Thanks!!!
    General #0
    Count : 177
    Count of stream of this kind : 1
    Kind of stream : General
    StreamKindID : 0
    Count of video streams : 1
    Count of audio streams : 1
    Count of text streams : 0
    Count of chapter streams : 0
    Codecs Video : MPEG-1 Video
    Audio codecs : MPEG-1 Audio layer 3
    File extension : mpg
    Format : MPEG-1PS
    Format : MPEG-1 Program
    Format/Family : MPEG-1
    Format/Extensions : mpeg mpg
    Codec : MPEG-1PS
    Codec : MPEG-1 Program
    Codec/Family : MPEG-1
    Codec/Extensions : mpeg mpg
    File size : 204417024
    File size : 195 MiB
    File size : 195 MiB
    File size : 195 MiB
    File size : 195 MiB
    File size : 194.9 MiB
    PlayTime : 744432
    PlayTime : 12mn 24s
    PlayTime : 12mn 24s 432ms
    PlayTime : 12mn 24s
    PlayTime : 00:12:24.432
    Bit rate : 2196756
    Bit rate : 2197 Kbps
    Video #0
    Count : 74
    Kind of stream : Video
    StreamKindID : 0
    Codec : MPEG-1V
    Codec : MPEG-1 Video
    Codec settings/Matrix : Standard
    PlayTime : 743700
    PlayTime : 12mn 23s
    PlayTime : 12mn 23s 700ms
    PlayTime : 12mn 23s
    PlayTime : 00:12:23.700
    Bit rate : 2544000
    Bit rate : 2544 Kbps
    Bit rate mode : CBR
    Width : 720
    Width : 720 pixels
    Height : 480
    Height : 480 pixels
    Aspect ratio : 1.500
    Frame rate : 29.970
    Frame rate : 29.970 fps
    Standard : NTSC
    FrameCount : 22288
    Interlacement : PPF
    Interlacement : Progressive
    Bits/(Pixel*Frame) : 0.246
    Delay : 500
    Delay : 500ms
    Delay : 500ms
    Delay : 500ms
    Delay : 00:00:00.500
    Audio #0
    Count : 59
    Kind of stream : Audio
    StreamKindID : 0
    Codec : MPEG-1A L3
    Codec : MPEG-1 Audio layer 3
    Codec profile : Joint stereo
    PlayTime : 744432
    PlayTime : 12mn 24s
    PlayTime : 12mn 24s
    Bit rate : 128000
    Bit rate : 128 Kbps
    Bit rate mode : CBR
    Channel(s) : 2
    Channel(s) : 2 channels
    Sampling rate : 48000
    Sampling rate : 48 KHz
    SamplingCount : 35732736
    Resolution : 16
    Resolution : 16 bits
    Delay : 500
    Delay : 500ms
    Delay : 500ms
    Delay : 500ms
    Video0 delay : 0
    USA
    You can't use MP3 audio with a DVD. Your Ulead program may have converted them to WAV or PCM audio, which will be much larger. Convert the audio to AC3 or MP2 and that may fix the problem. For the DVD specs, see 'WHAT IS' DVD to the upper left on this page.
  3. Member LJB's Avatar
    Feb 2007
    If you use SUPER to encode to MPEG-1, why not have SUPER encode to MPEG-2 with AC3 audio?
  4. Member Cornucopia's Avatar
    My thoughts exactly...
    Mar 2007
    I tried AC3 before on some other file and Ulead Movie Factory wouldn't accept it for some reason. I will try converting to MP2 as see if that works. Thanks.
  6. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Sounds to me as if MF is converting your video . If the file you generated in Super is DVD compatible using the "do not convert compliant files" option should leave the files as is and greatly speed up the process. Suggest you look it up in the manual.
    Add to that why not just import your MPEG's into MF, set the bitrate appropiately and let it convert the files?
    As far as AC3 goes that's quite an old version and may not support it.
