Hi All:
I am working on my files in Sorenson Squeeze 4.5 and have found after compressing, my files are still pixelated!
I am working on .movs, 720x480, so I don't see why they are so pixelated.
Any thoughts?
Thanks!
When you say that they're "still pixelated," that would seem to imply that the source file is already pixelated (which I assume you are referring to macroblock artifacts). If that's really what you meant, then Squeeze can hardly be expected to de-block magically. Lost information is lost information, and certainly recompression won't help.
Now if you didn't quite mean "still", and your source files are actually ok, then macroblock artifacts can result from insufficient data rate. You didn't provide much information in your post, so all we can do is shoot in the dark. In any case, crank up the bitrate and see if things improve.
Sorenson Squeeze 5.0 and QT
By rotuts in forum MacReplies: 3Last Post: 9th Dec 2010, 16:41 -
Sorenson Squeeze 5: Presets
By kr236rk in forum Video ConversionReplies: 1Last Post: 27th Oct 2008, 08:56 -
Sorenson Squeeze
By kr236rk in forum Video ConversionReplies: 36Last Post: 27th Oct 2008, 08:50 -
Sorenson Squeeze Problem
By seven_deuce offsuit in forum Video ConversionReplies: 0Last Post: 15th Nov 2007, 22:24 -
sorenson squeeze 4.3 problem
By Davide vr in forum MacReplies: 0Last Post: 12th May 2007, 21:55
