Hi guys
I wrote a very simple utility to convert subtitles from PAL to pulled-down NTSC (or in other words, to stretch them by 25/23.976). So when you convert a DVD from PAL to NTSC using 3:2 pulldown you can run the subtitles through the utility and then mux them and they will show fine.
I know that theoretically I could have used the DGPulldown method and this wouldn't have been necessary but I tried with the help of this thread https://forum.videohelp.com/viewtopic.php?t=312479 and the resulting DVDs would not play in either my NTSC-only combo or in the stand-alone, only in my computer (which can play PAL to start with). I guess if you make cheap NTSC-only stuff you don't care too much about exotic pulldown flags...
Anyway, I'm attaching the utility - it's too small to have its own web page.
Hope this helps,
[/url]
suptime.zip
Doesn't work. I tried the procedure listed with PAL-DVD extracted VOBs, and it retimed them shorter (rather than longer). Adding np or pn to the end did not produce the desired retimed-longer NTSC subs.
There are plenty of other programs that can already do that. I use SubtitleCreator for this purpose all the time.
Spinrite HDD Utility
By Noahtuck in forum ComputerReplies: 14Last Post: 22nd Jul 2009, 01:47 -
Best utility to backup drivers?
By alegator in forum ComputerReplies: 2Last Post: 20th Jan 2009, 14:50 -
Looking for a good wireless utility.
By dimtim in forum ComputerReplies: 1Last Post: 4th Oct 2008, 18:33 -
Anybody have DVXCEL Test Utility?
By codeseven in forum Capturing and VCRReplies: 0Last Post: 8th Apr 2008, 18:11 -
Burn in Disk Utility
By andredanton in forum MacReplies: 4Last Post: 12th Feb 2008, 12:41
