I've been buying some HD DVD's to expand my collection, and the fuckers scratch easily in the XBOX 360 HD Player
I was wondering if its possible to go from HD DVD to HD Content on a DVD-R and play back through the XBOX 360
HD DVD > HD Content on a DVD-R(or 2 or 3 if nessicary) > XBOX 360??
Thanks for the help as always!!!
-dr.p
Currently it is impossible IMO. But you can experiment. Cut the streams (how? well, i don't know) try to add all other necessary files, burn as data DVD (or Video DVD, if it is at all possible) try to play...
Use DVD RW if they are supported in xbox and so on.
I think there is no application which can do it at the moment. If you can cut enough short chunks you can use last version of Ulead movie factory (I think) to author HD DVD, but only mpeg2 files. If they are h.264 - well I don't know.
Need Help with Panasonic DVD-LS83 or DVD-LS86 8" Portable DVD Player!
By Big C in forum Portable VideoReplies: 3Last Post: 1st Aug 2011, 17:35 -
Samsung DVD-HR753 DVD and HDD recorder rejected all my blank DVD
By undangltn in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Mar 2010, 12:34 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 08:14 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 17:59 -
DVD+/-RDL Playback on Yamaha DVD-C750, DV-C6770, and DVD-C950
By Big C in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Aug 2007, 08:59
