Just added new ati "tv wonder ve" capture card and now my tmpgenc wont open the d2v files. [Even ones that I had just opened an hour before installing card] I am sure it has altered some codec's setting or priority, I just cant find where. I have tried the standard checklist below found on a search of this forum - to no avail - any other ideas?
OK, here is the checklist:
dvd2avi.vfp is in the same directory like dvd2avi.exe
TMPGEnc.vfp is in the same directory like TMPGEnc.exe
run TMPGENcVFP_INSTALL.bat
check TMPGEnc vfp is registered to VFAPI (TMPG>option)
check VFAPI plugin (dvd2avi>help)
TMPG> option> enviromental setting> VFAPI> check dvd2avi project file reader and/or select a higher priority.
Do not delete or move the .vob files. Open *.d2v with wordpad to check the correct path.
I am not sure if this will lend any clue to one of the experts but the above problem of using tmpgenc appears to be limited to dvd's because I was able tonight to convert an avi file from a Divx movie into a SVCD with no problems
ATI AIW 9800 Pro worst capture card ever?
By veedeo in forum Capturing and VCRReplies: 15Last Post: 1st Jan 2011, 18:41 -
ATI or NVIDIA capture card for VHS?
By Smile_M in forum Capturing and VCRReplies: 1Last Post: 13th May 2010, 06:43 -
Capture analog with camcorder or ATI card?
By Onceler2 in forum Capturing and VCRReplies: 7Last Post: 28th Nov 2009, 07:25 -
ATI AIW 9700 pro capture card problem
By INFRATOM in forum Capturing and VCRReplies: 8Last Post: 31st Mar 2009, 11:26 -
resolved: Need source for software for capture through ATI VIVO card
By palouse in forum Capturing and VCRReplies: 5Last Post: 7th Jun 2007, 10:56
