Is there an application that will let you look at and or listen to the different streams of audio that are on a DVD and then pull a specific stream only? Like say for instance I only want the music and effects and voice.....but not the narration. Not unlike on a foreign DVD where they speak in english over the actual language used.
Thanks.
-vodmare.
If the audio is a 5.1 .AC3 file, you can use Tranzcode to create 6 individual mono WAV tracks. Listen to each and hope for the best.
Yeah, but who knows - he might....
Tranzcode:
tranzcode_v0.40.zip
1) Unzip, place .AC3 file in same folder as app and double click Convert2monowavs.bat
2) If you're lucky, you'll see 6 mono wavs
3) If you only end up with 2 mono wavs after the conversion, then the answer is "Nope"...
Two Different Audio Streams In The same VTS.
By GangstaRap in forum Authoring (DVD)Replies: 7Last Post: 22nd Jan 2009, 10:00 -
OSX Program to Extract streams from .m2ts?
By marklight in forum Video ConversionReplies: 1Last Post: 11th Sep 2008, 23:27 -
Video with 2 Audio Streams TO mpeg1 with 1 audio stream
By Xenogear900 in forum Newbie / General discussionsReplies: 1Last Post: 5th Aug 2007, 19:00 -
multiple audio streams
By Tobberian in forum AudioReplies: 2Last Post: 14th Jul 2007, 12:54 -
Dual Audio Streams
By BobafettBH in forum AudioReplies: 0Last Post: 9th Jul 2007, 16:02
