I'm using DVD2SVCD to create "backup" DVD on SVCD, it works great !
Now, I want to convert divx to Svcd with the "foolproof" method here at VCDhelp. But when I put a .vdr file in CCE 2.50 (trial) on windows Xp pro(Tbird 900mhz), CCE CRASH in the transcoding windows..... I don't understand why CCE crash, because it works perfectly in DVD2SVCD. I tried it on a celoron 366mhz ...same thing !
What am I doing wrong ?
PLEASE help me !
CCE does not work with a Celeron 366, that is normal.
CCE SP 2.5 does not work with a AMD CPU if you try to encode audio.
When does cce crash and do you get an error message?
btw, dvd2svcd use Avisynth to frameserve and it does video and audio seperately, so it is hard to compare. -
I get no error message. It freeze instanly when I load a .vdr file (with framserving in virtualdub) or a sample avi file with no audio !!!! I re-install the cce 2.50 trial ; same thing. With the 2.62 I have no problem with avi file, but it does not support .vdr file.
It may be a winxp specific problem.
https://www.videohelp.com/phpBB/viewtopic.php?t=67983
Have a look at stanwebbers replies.
Intensity Pro firmware update problem on windows 7 pro 64Bit
By ulva in forum EditingReplies: 1Last Post: 5th Oct 2011, 07:00 -
Problem DVD Rebuilder Pro: Is not a ECL for CCE SP Trial Version
By Talayero in forum DVD RippingReplies: 2Last Post: 30th May 2008, 13:25 -
Premiere Pro CS3 unable to edit HDV??? (not trial version)
By Digipat in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 9th Feb 2008, 23:12 -
Premiere Pro CS3 trial
By MarioB in forum ComputerReplies: 1Last Post: 19th Oct 2007, 09:25 -
DVD Rebuilder Pro & CCE in Multipass VBR mode
By devnulllore in forum Newbie / General discussionsReplies: 12Last Post: 30th Jul 2007, 09:04
