  1. I downloaded the latest besplit software, but I'm too stupid to use it. Unfort. there isn't any "how to" guide on the tool's website.
    So....all I have is the file besplit.exe. I tried doubleclicking it...nothing happens. I do realize I have to write a script, but how do I execute it with besplit? I tried saving it as .txt and dragged it to besplit...nothing happened.
  2. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    See http://besplit.doom9.org/
    You'll find
    WBIAS 0.81 User-friendly BeSplit frontend for cutting multimedia streams
    by Well Being. (Packed with BeSplit v0.82)
    BeSliced 0.2 A BeSplit frontend for creating dummy audio streams and fixing audio streams (Packed with BeSplit v0.82)
    I think you'll find a few text files giving some examples of use of the command line version with BeSliced (You need to know something about DOS batch files to use this.)
    Many of the options are the same as BeSweet, for which there is more complete documentation.
    USA
    There should be a couple of GUI programs packaged with it if you don't want to learn the command lines, WBIAS and BeSliced 0.2 There are some other GUIs at: http://besplit.doom9.org/
    A command line program doesn't run in Windows directly.
    What are you trying to accomplish? There may be other programs that can do it also and may be a little easier to use.
