I am trying to burn an avi file to DVD, but am having the following problem. The avi is from a reliable source, but the problems I am having is this. I downloaded the avi but am unable to burn it to dvd as when I try to load it to NeroVision it comes up with an Application Error referring to: The instruction at "0x006b6c44" referenced memory at "0x01503940". The memory could not be "read".
I have also tried burning to DVD using ConvertXtoDvd, but it locks up after 5 minutes. Has anyone else come up with these problems or know how to fix?
Results 1 to 10 of 10
The problem is most likely related to the AVI to mpg conversion process, not the burning process.
Like guns1inger says, there's something wrong with the source AVI.
Even if you can play the AVI from end to end, this can still be true, as playback software simply ignores the occational error, where encoders require each and every bit in the AVI to be correct.
/Mats -
Hi I had the same issue with this message:
(when using nero vision express3)
After using both g-spot & Vdub, what is the next step to make it work??
Thanks -
Yes, it plays from on windows media player, vlc , win player and real player
convertxtodvd error
By loa909 in forum Newbie / General discussionsReplies: 6Last Post: 23rd Sep 2010, 15:13 -
burn multiple video files on 1 dvd using ConvertXtoDVD
By sascha_ in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2010, 06:09 -
ConvertXtoDVD 4 gives error when authoring multiple titles
By Sikander in forum Authoring (DVD)Replies: 7Last Post: 10th Jan 2010, 19:05 -
ConvertXtoDVD wont burn movie
By hewhoeatsall in forum Authoring (DVD)Replies: 1Last Post: 14th Dec 2008, 19:58 -
ConvertXtoDVD to encode and burn video files to DVD
By crowheart in forum Video ConversionReplies: 15Last Post: 16th May 2007, 22:50
