My DLP accepts 1080i through component input. My question is, is there any difference in video quality using component instead of HDMI? What I do know is that with comp, I will need to run audio cables for the sound, which is all run through the HDMI (both video & audio)
In short:
Is there a difference in video quality between running 1080i thru component vs HDMI?
I ask this because my tv only has 2 HDMI inputs.
What We Do In Life, Echoes In Eternity....
There is if the device has HDCP and downconverts everything other than HDMI.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
I doubt you'd actually notice the difference. The only thing HDMI is a must for is running 1080p content, but since your TV is only 1080i/720p I don't think it'll make much difference. Even less difference if you use some quality cables.
Do you run the audio to your TV or a receiver.FB-DIMM are the real cause of global warming -
ive seen some panels look BETTER with component then with HDMI
The reason I'm thinking of going comp over my 2nd HDMI input, is because the second HDMI is mainly for a PC connection (i.e. the color correction only offers contrast, brightness, and something else). Where as HDMI-1 has green, red, cyan, magenta, and a ton of other options, which I also believe is the same options with my component inputs (3). Thanks for the help
HDMI vs. Component for 1080i?
By Xylob the Destroyer in forum DVB / IPTVReplies: 12Last Post: 7th May 2010, 14:29 -
Blu-Ray 1080i Component VS. HDMI
By nerd_pH in forum DVB / IPTVReplies: 4Last Post: 5th Nov 2009, 13:48 -
What is a good DVD Recorder that has Component and/or HDMI Input(s)?
By KingKRool2002 in forum DVD & Blu-ray RecordersReplies: 37Last Post: 26th May 2008, 21:08 -
DVD Recorder that accepts HDMI or Component input
By AuditSup in forum DVD & Blu-ray RecordersReplies: 3Last Post: 26th Aug 2007, 02:39 -
Is 1080i thru Component the same video quality as 1080i thru HDMI?
By Denvers Dawgs in forum DVB / IPTVReplies: 27Last Post: 13th Jul 2007, 17:25
