Hi guys,
I used DVD shrink to copy a DVD and I had it pull all the audio off of the disc including the 5.1. But the .AC3 files appears to have narration over it. I assume this is an option when you play the DVD that you can play or not play. I know because when I watched the movie there was no narration, just subtitles.
Anyway, I want to get rid of the narration completely and keep the underlying effects, music, etc. I thought that by pulling all the audio somewhere down the line I would be able to either have an option or use an application to extract the audio that I wanted.
I guess what I want to know is, if this is even possible and if there is such a program out there that will allow me to do so.
Thanks in advance for any help.
-vodmare.
You simply chose the wrong audio stream to keep. You need to re-rip the disc.
I checked off all the available English channels. Before I ripped it with just the 2 ch. english ones. I disabled all the french and german channels......
So I don't know.
Is there are good program that you know of that does a good job of showing you what channels are what and ripping them from DVD easily. Maybe rip just the audio and not the video?
Thanks man.
-vodmare. -
Yep...DVDShrink.
Right click in the preview window and you can switch the audio streams(that you are listening to) and find the correct one to keep. -
I know this isn't the DVD shrink support forum, but I read on DOOM9 about what you are talking about and I followed the steps. The only problem is that I don't get a preview in the preview window. It's black and the play button is grayed out even after I analyze the disc.....If I cannot preview then I cannot select the stream to use/not use.
Any ideas ?
-vodmare. -
You gotta to be S**** me!
My GOD. Thank you man.
boy do I feel dumb.
-vodmare. -
Normally preview IS enabled by default. I was just hoping it wasn't something more serious that I couldn't help with...
Seperating MKV 3D files
By Mike001 in forum EditingReplies: 1Last Post: 15th Oct 2011, 01:28 -
trying to extract the 7.1 channels (8 channels) from Blu-ray disc
By billsantos in forum AudioReplies: 2Last Post: 20th Feb 2011, 15:28 -
Avi program for audio channels
By romanstopme in forum ComputerReplies: 2Last Post: 19th Nov 2009, 02:14 -
DVD with two audio channels
By Anurag in forum DVD RippingReplies: 6Last Post: 20th Apr 2009, 00:15 -
AVI with two audio channels - How do I remove one of them?
By egotrip21 in forum AudioReplies: 6Last Post: 20th Aug 2008, 21:15
