Results 1 to 11 of 11
QuEnc can encode both Video and Audio. HCEnc only encodes Video. I usually use HCEnc for the Video and QuEnc for the audio (it can do audio only). IMO HC does a little bit better job of respecting maximum bitrates. In the tests that I did when evaluating for myself, I didn't see any difference in quality when I viewed them side by side. I recommend you test for yourself and make your own decision.
Buy My Books -
Just for the record QuEnc can do AC3 audio (which is what I always use).
ffmpeggui is a good conversion/encoding tool, but what I like about QuEnc is that I can feed it the same avs script that I used for HCEnc. To my knowledge there's no way to do that with ffmpeggui at the moment, so if I make trim edits in my script then I have to save the audio out to wav via Vdub then encode separately."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
Read my blog here.
Aften is a good freeware AC-3 encoder ... better perhaps than ffmpeggui.
As for Quenc vs HCenc ... I tried Quenc a while ago and was not impressed with the quality whereas I am very impressed with HCenc. Perhaps Quenc has become better since ... can't say.
I will say this ... don't let the fact that HCenc being a video only tool scare you away. Just about all of the really good encoders either can't do sound or do it poorly so it is not uncommon to use one tool for video and another for audio.
thank you all for your suggestions. I have used HCenc in the past, it was good. Also, I have lots of DV tapes and I want to recycle them but don't have time to edit the footage. I am going encode and store them on my hard drive for now. My editing involves no more than deleting some footage. Can I use virtualDubMod for doing that (I used virtualdub for deleting some footage from DV-avi file)? If so, how do I delete the video and the corresponding audio as they are now in separate files.
I know it is better to edit the avi files rather than encoded mpeg files, but I am not that worried about quality. Thank you for your answers. -
I disagree with this statement and view it as out of date. Many AVI junkies don't realize that the MPEG world has had frame accurate editors for some time (VideoReDo and MPEGVCR for example) and they don't re-encode your video as the result of your edits. Whether you can actually tell the difference or not between AVI edited video that is converted to MPEG-2 or MPEG-2 video that is then edited is a very good question. Some people swear that they can and although I firmly think they have a minority opinion, I can no more prove that they are wrong than they can prove that they are right. If you're just doing simple edits, such as removing commercials, I doubt it makes any difference whether you edit first and then convert or convert and then edit. I've known of people who think 128 Kbps MP3 is as good as original CD source and I've known others that think that anything below 256 Kbps is crap. I just point out that just because some people are convinced that you HAVE to edit in AVI first or the quality will suffer is debatable and you might have a different opinion.Originally Posted by malahal
What would be the best free MPEG2 encoder?
By CursedLemon in forum Video ConversionReplies: 12Last Post: 20th Sep 2010, 23:10 -
Cedocida still the only DV free DV encoder to use?
By sphinx99 in forum Video ConversionReplies: 0Last Post: 19th Mar 2010, 22:45 -
Best (free or commercial) FLV encoder for windows?
By sdsumike619 in forum Video ConversionReplies: 1Last Post: 25th Oct 2008, 18:17 -
best free DV to DVD encoder???
By tmh in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 7th Mar 2008, 13:39
