Hi
a newbie with a couple of questions before i start to turn all my old VHS rugby tapes to DVD. I have purchased a bog standard BUSH dvd recorder/vhs combo DVRHSO2 which records on dvd+r . What are the reputed best dvd+r to use for the task and also .What is "finalizing a disc all about i will be editing them on a nec dvd writer on my pc that runs most things ok I just want to be prepared with good advice,Any pitfalls i would be glad of the information
regards Pat
If the tapes are ones you recorded yourself, you shouldn't have any problems. If they are bought tapes though, they may well be protected with macrovision which means your dvd recorder will refuse to copy them. Finalising a disc means that it can be read by another drive, until it is finalised it can have further content added to it and can only be read by the drive that burned it.
Taiyo Yuden are normally reckoned as being the best you can get in DVD-R, but I'm not sure about +R. Have a look here http://svp.co.uk/products-list.php?bid=0&cid=115 and look for the customer ratings. -
I've done more than a few. I use a re-writable in the recorder and simply use DVDShrink if all I want to do is trim the start/end. Then I burn to my disc of choice, Verbatim -Rs. With my Pioneer recorder I have a choice of VIDEO or VR mode. I use VIDEO which creates a standard playable DVD.
Could anyone please advise me on how to download this video?
By aveceux in forum Video Streaming DownloadingReplies: 0Last Post: 5th Apr 2012, 05:08 -
Need recommendation-Beginner-Video-Editing softwater/computer
By TeaOlive in forum Newbie / General discussionsReplies: 10Last Post: 20th Jun 2010, 14:06 -
Posts for beginner, video conversion using C#
By alsuse in forum ProgrammingReplies: 9Last Post: 28th Nov 2009, 06:35 -
Vista beginner needs help with video conversion! Xvid to VCD with subs
By Joakim_A in forum Video ConversionReplies: 2Last Post: 23rd Sep 2007, 03:59 -
Best video editing software for a beginner
By meloo72 in forum EditingReplies: 4Last Post: 9th May 2007, 18:37
