Well..... last night I decided to convert a divx file to a super video cd. It took about 24 hrs because my computer sucks much, but now I need to cut the file, into about 3 or 4 cd's. Here is my problem:
I know that you can't fast foward SVCD's, but only on a DVD player right?? Well I don't know. So I started up TMPG enc, and went to File-MPEGTools-Merge&Cut. When I opened the file, I wasnt able to to select where I wanted to start or stop on the preview window thing. When I did, the video would move like really fast (about 200fps) and the audio was normal, so obviously way off the video. So I downloaded the SVCD codec for TMPGenc on the tools page>>>>>>>>>> >>>http://www.vcdhelp.com/download/mpeg2codec_installer.zip<<<, and I restarted and I opened up TMPG and the same thing happened. So I then De-Multiplexed it and remultiplexed the file and tried cutting the file. This still didnt work. Can anyone help me out??
What the Fuc is the internet?
Take a look to the left under "Edit" and read teh guide on how to cut w/ bbMPEG (or wobble). Basically:
1) Demux MPEG in TMPEGenc
2) Load M2V + MPA/MP2 files in bbMPEG
3) Choose cut points or max size\
4) Run (ie. cut)
I need to cut a MOV file
By a11111 in forum EditingReplies: 10Last Post: 30th May 2016, 15:18 -
Cut a part from a MKV file
By H2SO4JB in forum Video ConversionReplies: 0Last Post: 17th Oct 2010, 09:15 -
Can you cut this file losslessly?
By tokintmash in forum EditingReplies: 17Last Post: 10th Mar 2009, 01:57 -
cut vob file
By xxxjojoxxx in forum EditingReplies: 8Last Post: 25th Dec 2008, 09:06 -
how to cut a wmv file
By stranzer in forum Video ConversionReplies: 5Last Post: 22nd Jun 2008, 11:26
