After ripping and burning to ISO w/Decrypter, I got this message while burning:
I/O Error!
Device: (1:0:0) MATSHITA DVD-RAM UJ-841S 1.50 (D(ATA)
ScseStatis:0x02
Interpretation: Check Condition
CDB: 2A 00 00 1E C2 A0 00 00 20 00
Interpretation: Write (10)-Sectors: 2015904-2015935
Sense Area: 70 00 05 00 00 00 00 0A 00 83 00 00 30 05 00 00 00 00
Interpretation: Cannot Write Medium-Incompatible Format
Since the error message popped up at the 42% complete mark, I was wondering if the drive is having trouble actually burning DL even though its rated to do so. I know for a fact it should, as I already pm'd another user with the same drive who's been able to burn DL with Nero. I was using Intervideo WinDvd (which came pre-loaded on my Toshiba laptop) for previous single layer burns with no problems using Taiyo Yuden and Verbatim discs. However, when using WinDvd with a Verbatim DL in the drive, windvd recognizes it as DL but refuses to burn to it, saying 'there is not enough space on the disc'. I've tried to find firmware updates for the drive, but no luck.
That's when I decided to give decrypter a try, but got errors when burning in both File and ISO mode. I was thinking of trying IMGburn next, so if anyone has any advice or tips on proper settings for DL burns, I'd greatly appreciate avoiding any more coasters.
DVDDecrypter wsn't designed with dl media in mind ... however you can still use it to rip your dl dvds but you should burn it with IMGBURN as this will sort out the layer break that dvddecrypter can't handle
dvddecrypter - iso read (on the mode tab)
imgburn - write (on the mode tab) -
spyder67,
Here's a link to the guide for using ImgBurn to burn VIDEO_TS - AUDIO_TS folders to a dual layer disk. Doing it that way, and not using an ISO, will give you the best probability of success.
If there's a problem with the burn, post the burn log, and we should be able to diagnose the error.
For that general class of error, things to check would be:
1) Other programs running during the burn are interferring
2) ASPI layer configuration error (not a problem if you're using SPTI available in XP)
3) Medium problem (not likely if you're using Verbatim DL)
4) Drive malfunction -
Thanks for the tips, guys. I'll see if I can try it out this weekend and post the results.
ImgBurn rocks! Special thanks to VegasBud for the 'quick and easy guide' link for burning as video and audio TS folders rather than ISO. Since I already had the TS folders from ripping with dvdshrink, I decided to use that instead of ripping again with dvdfab or decrypter. After reading about the potentially faulty way dvdshrink groups the BUP files though, I'll probably use something else for ripping in the future.
Don't worry about that as ImgBurn adjusts for 32k gaps.
Even better is VobBlanker. Use its Adjust Sectors (In Input Folder) function to space IFOs and BUPs opposite each other on the DVD (make this your last step in authoring/editing).
Then burn with ImgBurn.
RegardsLes
Problem erasing a Verbatim DVD+RW
By nadizo in forum DVD RippingReplies: 10Last Post: 2nd Mar 2009, 07:56 -
burning a dvd with dvd decrypter
By shashgo in forum Authoring (DVD)Replies: 1Last Post: 29th Dec 2008, 17:34 -
DVD Decrypter Problem
By WuPhilly in forum Newbie / General discussionsReplies: 14Last Post: 17th May 2008, 16:28 -
question about DVD HD Fab Decrypter/Burning
By Bamahusker in forum DVD RippingReplies: 22Last Post: 19th Nov 2007, 11:33 -
Burning speeds and DVD Decrypter...
By Nilfennasion in forum Newbie / General discussionsReplies: 6Last Post: 20th May 2007, 04:32
(ATA)
