  1. I just bought a Cingular 8525 and when I use the video recording function it saves them as .MP4 and plays them in Windows Media Player Mobile. What I'd like to find out is how I can make a compatible MP4 file for WiMP Mobile from my PC. Any ideas?
  2. Member ebenton's Avatar
    Jul 2003
    The WINDY state (Florida)
    If you have Windows Media Player on your 8525, it will play WMP files just like your PC. If you can make WMP files, they should play on your 8525 without changing them. You do not need to make MP4.
  3. I have tried using WMV files but wouldn't MP4 save a lot more on space?
  4. Member ebenton's Avatar
    Jul 2003
    There is a program called Pocket DVD Wizard. It will ask you how big your memory card is, and will compress the video according to how much room you tell it you have. Since you are only talking about a 320 X 240 screen, the video quality is not as important is it would be on your desktop PC.
