It will stay on the classic start menu, but not the "windows classic style" (and my appearance settings)
When I reboot it just goes right back to what it wants "Windows XP style"
Is there a way to fix it? Windows XP looks stupid.
I prefer windows 2000 but can't have the 2.5 minute bootup time.
Results 1 to 22 of 22
Assuming you are logged in as the admin or have admin priv, it should be keeping the settings you have chosen. You aren't using a third party app like window blinds are you?
Google is your Friend -
Logged in as Admin, yes, it is set to assume that "Administrator" is logged in
No third party app like that -
Are you setting it to Classic style from the "Appearance" tab in the display properties, or the "Themes" tab? Use the Themes tab to set your display to Windows Classic, and that'll update the Appearance tab. If that doesn't work, then something's broken.
RIght click desktop - APPEARANCE TAB - "Windows and Buttons" set to WINDOWS CLASSIC STYLE - ADVANCED <---- That's where I set the colors and bar sizes and all
Then I reboot and POOF everything is default XP BS -
Once you've done that, click on the themes tabOriginally Posted by The Fred
Click on "save-as" and save your new modified theme -
Hit the themes tab instead, and select windows classic as the theme. Then hit apply and ok.Originally Posted by The FredBelieving yourself to be secure only takes one cracker to dispel your belief.
You can also right click on the task bar...Select properties....Select your preferences and "apply"....
If you Google XP SP3 one of the links that comes up is: http://www.pcworld.com/article/id,122871-page,1/article.html?RSS=RSS
Windows XP SP3 Preview Surfaces Online
"Unofficial" preview pack includes log-on improvements and network fixes for Windows XP PCs. -
Well it is at it again... *sigh*
Can't throw it out the window because it is in a HUGE case, it even has casters on it,
Is there any way to fix it without installing a whole third party(s) mess of a service pack? -
SP3 is not official.Originally Posted by handyguy
You may see patches that will be in SP3, but technically, there is no SP3.Believing yourself to be secure only takes one cracker to dispel your belief. -
There is no sp3 yet. So don't waist your time. What would a sp have to do with saving your desktop theme anyway?
Not much.
Sometimes files get corrupted & that would take care of it, but it's been solved. -
I had this problem two weeks ago. On a recently formatted computer my Windows started to get back to XP style, not the classic.
One day it started with the XP style and I didn't change for the classic style, after some minutes using the computer it changed for the classic style, automatic, without changing any config. After that every reboot kept the classic style.
Yesterday I had to format the computer to change some stuff and changed for the classic style. Today I made some updates (2 IE7 critical updates and the other one was a JVM update). Rebooted when asked and there it was, XP style again.
I'm keeping this to see if it will change automatic. But seems like some windows update feature is messing it up :/ -
Well, it didn't change.
Had to save the classic style configs with another name and now it's ok.
Strange behavior, anyway. -
Not so easy.
Just rebooted and XP style came up again. :/
dvd tray won't stay closed
By toddster385 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 4th Apr 2011, 12:49 -
Canon Hi8 A1 won't stay on
By Sew Sporty in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 3rd Jan 2011, 20:51 -
PC Monitor Won't Stay On
By The Monkees in forum ComputerReplies: 4Last Post: 10th Mar 2008, 23:15 -
Computer keeps shutting down, won't stay on.
By Super Warrior in forum ComputerReplies: 6Last Post: 9th Aug 2007, 15:34 -
OGMDemuxer won't stay open...
By deepdiev in forum Video ConversionReplies: 3Last Post: 13th Jul 2007, 02:07
