    Jun 2005
    USA
    Hey guys,
    I'm looking for a decent tripod for my panasonic nvds-25 video camera. My budget is around $35 (unfortunately). Any suggestions as to where I can find and which ones is good?
    Thank you,
    Foton
  2. AGAINST IDLE SIT nwo's Avatar
    Jan 2004
    Stadium Of Light
    try ebay, can't see your getting anything good for $35 in any shop.
    May 2007
    Hello, I have one like the one pictured on this link:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16830994017
    Works great, I havent had any complaints.
    Hope this helps.
    Any tripod is better than none at all. And to help out a cheap tripod, you can add weight by hanging your camera bag or whatever you have to hand on it to improve stability.
    May 2003
    Peterborough, England
    I depends if you want to fix the camcorder or be able to pan/tilt it. The Newegg one, with additional weight, would be fine for a static shot but if you want to pan or tilt you'll need to spend a lot more for one with a fluid head.
