    Aug 2006
    Norway
    I'm playing around a bit with ScenalyzerLive 4.0. I have a DV clip on my harddisk that has a problem with the timecodes. No editing software can detect the scenes but Scenalyzer seems to be able to (optical detection). But how do I export the video files after scene detection? I can only export a html file and jpg thumbnails. The manual says I should "tag" the clips for the batch list but I can't seem to find out how. Is it only possible to split the scenes into different files directly from tape?
    Also does Scenalyzer work with canopus ADVC-300 or only the 3 Canopus devices mentioned on their homepage?
    Aug 2006
    Norway
    I was able to tag the clips and they show up in a window called Smart Batchcapturing. But when I press "Start!", Scenalyzer says: "There is currently no capture-device selected or avilable"
