So I'm my computer is rather old and slow at rendering video and I'm wondering if the process will speed up by changing to a single pass encoding option in premier pro rather than a 2 pass. Is there any reason I should avoid single pass?
basically I don't know what is different.
Multipass encoders use the first pass to generate statistics about the video to improve quality in the next pass, so you should expect the quality to be better with 2 passes than 1 pass. Yes, 1 pass encoding is quicker, but you are trading quick encode time for lesser video quality.
Difference Between 1 pass & 2 pass encoding
By iqbal88 in forum Video ConversionReplies: 28Last Post: 29th Oct 2021, 05:19 -
advantages of encoding vob/mpeg2 to h.264 using 3-pass instead of 2-pass
By codemaster in forum DVD RippingReplies: 8Last Post: 21st Sep 2011, 21:11 -
Technical Query Re Reading of 1st pass stats during second pass xvid encode
By onesikgypo in forum Video ConversionReplies: 1Last Post: 13th Mar 2011, 06:59 -
1 pass and 2 pass bit rate query
By socrates in forum Blu-ray RippingReplies: 1Last Post: 26th Nov 2010, 15:18 -
Retrospectively check if One Pass or Two Pass Encoding was used?
By BenjaminBS in forum Video ConversionReplies: 4Last Post: 26th Nov 2009, 05:46
