i am having a problem now with imgburn
i changed drom dvd shrink/nero because of a similar problem and you guys suggested imgburn
it go's through the whole process, but doesnt end up writing to the dvd...the process has completed post comes up but nothing.
It used to eject the disc and go through it twice, now it ejects and thats it...but nothing is done
very frustrating
Some info would be helpful! What are you backing up and progs used? what media was used? post a log.....????
Very curious" Who needs Google, my wife knows everything" -
Also, what operating system are you using? (for example Win XP, Vista, etc)
open imgburn ... click mode ... select write .... look near the bottom under 'destination' ... uncheck 'test mode' ... now burn as normal and the data will be written to disk ... (test mode does just what it says ... it test to see that the data will burn onto the disk .. but nothing is actually written)
play the file from your HHD, make sure its valid,
now burn it, if its not on the disc you have a media and/OR hardware dvd-burner problem not a software problem
Odd breaks in video/audio authoured with DVD Shrink 3.2 & Imgburn
By bahjan in forum Authoring (DVD)Replies: 1Last Post: 1st Sep 2010, 14:46 -
Problems backing up DL dvds using DVD Shrink and ImgBurn
By ManuBumb in forum Newbie / General discussionsReplies: 9Last Post: 7th Apr 2009, 22:35 -
Known problem with ImgBurn or DVD-Shrink?
By stockjunior in forum Authoring (DVD)Replies: 5Last Post: 26th Feb 2009, 16:12 -
discrepancy between dvd shrink and imgburn???
By m-man in forum DVD RippingReplies: 4Last Post: 12th Aug 2008, 16:59 -
Dvd Shrink + Imgburn
By angryassdrummer in forum Newbie / General discussionsReplies: 2Last Post: 2nd Dec 2007, 00:54
