i hope this is in the right spot but i have pinnacle studio quick start V9.4 and i curently have mad a vedio that is 45 minuts long that i can not get to fully burn. i have try to "make movie" 6 times now and it freezes in differnt spots every time. i have make 20 min videos several times will little to no probles.
My main question is why is this happening?
sencend, is it worth to update to to pinnacle studio plus v9 for the $20 bucks??
is there a better, but afordable software to use(new at this, i find this program easy to use)?
my sytem is a Dell 5150 win xp media, Pen D cpu@ 2.8, 2.0 gigs of ram, 230 gig hard drive, dvd rom, dvd burner, tv tuner card, 5.1 sound card
thanks for all and any help
Kris
Is hard disk space tight? Pinnacle Studio wants a fair amount of space for tmp files.Originally Posted by littlesweetboy
I have pinnacle studio 10.6 and it sucks. I got totally robbed when i bought this software. I bought the moviebox kit that contains the usb input device for capturing. This program is crash prone. I had to try 3 times installing this garbage because it regstration tool kept crashing. Now i'm having trouble with the update patch it keeps freezing. Please do not update for $20 you will be wasting your money. Look into some other software thats what i'm doing now.
Try:
1. Delete Temporary files (from File Menu)
2. Render your project as an AVI
If that works, then load the resultant AVI as a new project, then Create Disk, but set the options to create the Image on Hard Disk. Then if that works, either try Burnining the resultant Image witrh something else (Nero), or try again with Studio.
If Rendering the AVI fails, then try and determine where it is failing - Expand the Timeline fully and try and see if there are any 'small little glitches', or if it always fails on a particular clip or Photo. If it does re-edit those parts.
Pinnacle Quick Studio 10 question
By dbanimal in forum Authoring (DVD)Replies: 2Last Post: 24th Apr 2009, 15:21 -
I cannot start Vegas Movie Studio 9.
By scaperat in forum EditingReplies: 2Last Post: 11th Aug 2008, 12:46 -
Pinnacle Studio 8
By Victri in forum Newbie / General discussionsReplies: 1Last Post: 24th Dec 2007, 04:18 -
Pinnacle Studio 11
By fjmr in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2007, 03:44 -
PINNACLE STUDIO 11 vs. SONY VEGAS MOVIE STUDIO 8
By coody in forum Capturing and VCRReplies: 4Last Post: 26th Nov 2007, 18:53
