Hi everyone - I just built a PC (GeForce 7800 GT video card, 2 150 GB WD Raptor hard drives - 10K rpm, Athlon 4800 x2 CPU, 2 GB RAM). I built this PC to edit HD video and am wondering if I need an additional video capture card for capturing HD video from a camcorder. If an additional card is necessary, does anyone have any recommendations as to the make/model? Thanks!
Just getting my feet wet!
From a Camcorder? Usually, all you need is a Firewire port on your PC. Should Cost $20 for a card if your system doesn't have one.
Sorry, the camcorder is Sony's HDR-HC5.Originally Posted by edDVJust getting my feet wet!
I'm just resurrecting this topic because I just want to make sure I have my answer - I don't need a separate video capture card to capture HD video from my camcorder, right? On my old PC, I did use a Pinnacle capture card to capture composite- and S-video from an older camcorder, but I suppose the reason that was necessary was because my PC didn't have those kind of inputs. The new camcorder does have firewire outs, so I'm set, right?
Thanks everyone!Just getting my feet wet! -
The Sony HDV format camcorders offer two recording modes DV and HDV.Originally Posted by Big Chupa
DV is the older 720x480 SD format and is well supported by many applications. It's transferred over an IEEE-1394 (I-link) connection to the hard drive.
1440x1080i HDV is a form of MPeg2 and needs a specific application driver for transfer. Sony usually packages an application to transfer HDV to a file on the hard drive. Applications that support HDV have similar capability for HDV import.
Sony HDV camcorders also hardware downconvert HDV to DV for normal IEEE-1394 transfer so that you can edit today as SD 720x480i DV but save the HDV version on tape for the future. -
Thanks edDV and everyone!Originally Posted by edDVJust getting my feet wet!
Looking for recommendations for tuner card
By ucime in forum Capturing and VCRReplies: 6Last Post: 18th Mar 2011, 21:51 -
Capture card recommendations?
By dougieex0x in forum Capturing and VCRReplies: 1Last Post: 10th Jan 2011, 00:45 -
Recommendations for a Video Card
By bryankendall in forum ComputerReplies: 6Last Post: 25th Feb 2010, 16:15 -
Need recommendations re. AGP card(s)
By CBinSD in forum Newbie / General discussionsReplies: 14Last Post: 14th Aug 2009, 20:20 -
New capture card recommendations with some specfic features?
By justin81 in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2009, 13:00
