Using the latest version of Nero Recode, how can I set the thumbnail or album art that is shown in iTunes and my Apple TV?
Also, can i change the thumbnail for an already encoded mp4, or is it embedded in the mp4?
Thanks!
Gary
Found out that you can right-click a video while watching it, and select "Set Poster Frame" to set the thumbnail in iTunes. Haven't checked if it translates over to the Apple TV or iPod listings.
Also, this seems to work for Movies in iTunes, but multiple episodes of TV Shows that are grouped under one thumbnail don't seem to pick up the poster frame I set from one of the episodes. -
OK...confirmed that the Poster Frame does translate over to the Apple TV (via my streamed library...haven't checked a sync'd item).
Also found out that with multiple episode tv shows, the group will use the thumbnail from the first episode (noted by the Episode Number entry on the Video tab of Get Info). The Artwork tab in Get Info is somewhat dynamic, in that you can click to select the current artwork in the panel, delete it, and paste in the artwork from another item's Artwork tab (already copied to the clipboard). This method along with the Next and Previous buttons make it easy to set the artwork for an entire group of episodes to the same image (which means the group's image will be consistent also.).
It would be nice to be able to specify something other than the first item in the group for the group's thumbnail.
Album Art Browser
By JMNick in forum Software PlayingReplies: 0Last Post: 11th Nov 2011, 03:32 -
PotPlayer Album Art
By positcert in forum Software PlayingReplies: 3Last Post: 13th Sep 2011, 19:55 -
Album cover art
By ssaamm in forum ComputerReplies: 1Last Post: 1st Jan 2011, 10:53 -
MPC-HC freezes when when trying to open most MP3s with album art
By Typhoon859 in forum Software PlayingReplies: 18Last Post: 10th Aug 2009, 07:52 -
How to create album art for Movies?
By siratfus in forum Newbie / General discussionsReplies: 2Last Post: 1st Aug 2008, 06:23
